how develop strong pressure in the inlet?
Old   June 3, 2007, 10:54
Default how develop strong pressure in the inlet?
SURESH
How to generate strong pressure like 40 Mpa in the inlet in transient analysis? This pressure has to vary with time so that patching will not help. Is any possibility to generate this much pressure right from the first iteration since this pressure is not developed for me and very low pressure only developed intially.
Old   June 3, 2007, 23:28
Default Re: how develop strong pressure in the inlet?
AJ
What's the problem? What are you trying to solve for?
AJ
Old   June 6, 2007, 01:52
suresh
I am simulating flow in a pipe having some heat of reaction, mass . But the constraint is at t=0, the pressure should be at 40Mpa. Then this pressure will drop to 0. I converted this heat of reation as energy source and mass source , but the initial pressure 40 Mpa is not developing even after adjusting the volumes. But all other parameters temp, mass flow rate are o,k. How to develop this pressure at inlet?
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
How to achieve constant static pressure in inlet? Zou Jianfeng FLUENT 0 October 21, 2008 02:55
Question about pressure inlet boundary condition. Alina FLUENT 1 November 30, 2007 08:39
Pressure Inlet yields wrong velocities Ben FLUENT 0 November 21, 2004 02:47
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
