skewness
Old   June 1, 2007, 09:45
Default skewness
Donia
hi everyone, could you tell me how to verify skewness in Gambit!
Old   June 1, 2007, 15:05
Default Re: skewness
nick
hi donia, click on Examine Mesh (bottom-right button), Display Type: Range, select all element types, Quality Type: EquiSize Skew, Update. The green bar will give you info on the skewness distribution. You can also click on the Mesh Command Button (top-right button), right click on the "i" in the volume panel (or Face panel for 2D) and select "check", select the volumes (or faces) you want to check, Apply. Enlarge the Transcript window and see the info. See the manual for good mesh quality requirements.
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
TGrid High Skewness khimkhim ANSYS Meshing & Geometry 1 February 18, 2010 00:36
problem with skewness jjchristophe FLUENT 1 January 14, 2010 22:22
Severe nonorthogonality and severe skewness problem qtian OpenFOAM Running, Solving & CFD 2 January 22, 2008 19:47
Skewness Taskin FLUENT 5 April 6, 2005 16:21
