Animation Problem
Old   May 31, 2007, 08:19
Default Animation Problem
Salehi
Hi
I am trying to make an Animation of the velocity contours in a defined plane in my geometry, but when i playback the sequence-1, I can see just the geometry without any defined plane and no velocity contours.
How can I reach an animation with changing velocity contours in defined plane in the geometry?
thankx
Old   May 31, 2007, 09:29
Default Re: Animation Problem
Prasad Dudhgaonkar
Please follow this sequence: 1. Display-Option. Choose active window number and Open. Close dialogue box. 2. Solve-Animate-Define. Set animation sequence to 1. Select the frequency and When (per iteration or per time step). Click Define. 3. Choose contours as Display Type and click properties. Select the plane and set other desired attributes. eg. range. Set view and display contours. 4. Set window number to the same active window and click Set. Choose Metafile for storage and click OK. 5. Click OK on Solution animation dialogue box. Now if you try to change the view in the Set window, you won't be able to! 6. Now start solving. 7. You can replay animation as you want. You can write a MPEG file to present in presentations too.
Old   June 1, 2007, 18:13
Salehi
I thank you very much but at the end when I play back resulted animation, it was just a filled white geometry.
I choosed frequency = 20 (time step). and I did other setups like your description.
another problem: I could not set up another animation-sequence. Other window had showed just residuals.
Thanks
Old   June 2, 2007, 04:30
Amir
Hi if u follow Prasad certanly u reach an animation. if u want have another window u should set ir (step 4). ( if u didnt want see residual u should off plot option at solve >monitors>Residuals) Amir
Old   June 2, 2007, 04:31
Amir
Hi if u follow Prasad certanly u reach an animation. if u want have another window u should set it (step 4). ( if u didnt want to see residual, u should off plot option at solve >monitors>Residuals) Amir
Old   June 2, 2007, 06:30
Prasad Dudhgaonkar
By default window no 0 is allocated for residual plot. So you are finding residual plots, most probably, in place of animation. as As a thumb rule, you should set your monitor windows (surface monitors or other) and after that you should set animation windows. So allocate separate windows for each display. You can set as many animation sequences as you wish and also get different views for each sequence. You can change residual plot window number too via Solve-Monitor-Residuals.
conduction problem venkataramana OpenFOAM 3 December 1, 2013 08:30
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 06:29
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
