UDF basics PLEASE!
Old   May 29, 2007, 17:30
Default UDF basics PLEASE!
Paul
I really need some help here, maybe it seems quite simple but I have no clue:
I hadn't been able to use any UDF, I run Fluent from Visual Studio Net, right?..and then I try to compilate the UDF (from any of the available tutorials)...but it does not work.
Any of you could tell me if this could be something related with the way Visual Studio Net was installed..or how exactly is that Fluent is supossed to be run from this or another programme in order to be able to use UDF's?
Thanks a lot in advance!!
Old   May 29, 2007, 21:17
Default Re: UDF basics PLEASE!
Sham
Paul,
If you give me your e mail I can send you the instructions to compile UDF.
What sort of problme are you modelling?
Sham.
Old   May 29, 2007, 21:33
Charisse
set the "environment variable" such as: include E:\Program Files\Microsoft Visual Studio\VC98\include (the dir "vc\include")
lib E:\Program Files\Microsoft Visual Studio\VC98\lib (the dir "vc\lib")
path (the dir including the file "mspdb.dll",with different name according different version,such as mspdb80.dll)
Old   May 30, 2007, 05:35
Free
Hi i have same problem. after building i recived bellow message: 1 file(s) copied. (system "copy F:\Fluent.Inc\fluent6.3.26\src\makefile_nt.udf libudf\ntx86\2ddp\makefile")
1 file(s) copied. (chdir "libudf")() (chdir "ntx86\2ddp")() 'nmake' is not recognized as an internal or external command, operable program or batch file. 'nmake' is not recognized as an internal or external command, operable program or batch file.
if possible please help me. Best Free
Old   July 18, 2010, 17:23
Dave Smith
davesmith_01 is on a distinguished road
To Charissie
Hi could please explain this in more detail I dont understand what you are saying?
Thanks in advance
davesmith_01 is offline   Reply With Quote
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 08:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 22:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
