How to run DPM using UDF
Old   May 29, 2007, 16:29
Default How to run DPM using UDF
williams
Hello
Is there any method that I can call DPM using UDF after I set the DEFINE_INIT? I do not want the solver to calculate velocity field.
Thanks.
Path status in DPM BC UDF HS FLUENT 4 June 12, 2014 08:12
Parallel DPM Udf problem dust_2 Fluent UDF and Scheme Programming 4 June 11, 2011 11:03
how to access a variable in DPM within a UDF patrick FLUENT 13 September 15, 2010 09:38
So many questions in DPM & UDF - Help! URGENT! Prashanth FLUENT 0 March 3, 2009 23:26
DPM; particle seeded / deleted by UDF Laika FLUENT 6 January 23, 2006 00:40
