Laminar Zone in Turbulent Simulation
Old   May 28, 2007, 05:03
Default Laminar Zone in Turbulent Simulation
Demetrios
Hi everyone I am modeling a tube which "creates" slugs of air in water. The flow of the water in the tube is turbulent but the flow in the nozzle that feeds the air is laminar. How can i define that the zone that feeds the air is laminar?
many thanks
Old   May 29, 2007, 03:05
Default Re: Laminar Zone in Turbulent Simulation
Zamir Rashid
How do you know that the air feed is laminar flow?
Old   May 29, 2007, 09:09
Demetiros
The Re number is below 1000, so it must be laminar
Old   May 29, 2007, 21:28
Zamir Rashid
You can turn off turbulance modelling in a specified zone by turning on the 'Laminar Zone' option in the 'Fluid' boundary condition panel. You can also set the turbulent viscosity to be zero via the TUI.
define/ boundary-conditions/fluid
Set Turbulent Viscosity to zero within laminar zone?
if your response is 'Yes', FLUENT will set the production term in the turbulent transport equations and the turbulent viscosity as zero.
Refer to the FLUENT documentation for more info.
Hope that helps.
Old   May 30, 2007, 08:00
tom
Normally, the turbulent model will "feel" that the flow is laminar in that zone. Most of turbulent models production terms are based on gradients. in laminar flows, these will be smoother, and then the production reduced. first try to run a turbulent simulation and you should see that the eddy viscosity (or the tke) in your laminar part is far lower than in the turbulent one
Old   May 31, 2007, 07:40
Demetrios
i would like to thank both of you. I would like to ask you something else as well. Air is fed by a velocity inlet, and once i have turned viscous on it wants me to iput values for Turbulent Intensity, but as i said before flow is supposed to be laminar. How can make the Velocity Inlet Laminar (not having to input value for Intensity)? many thanks
Old   June 6, 2007, 11:36
tom
put a very low intensity. (less than .01%)
how to solve a problem involving both laminar and turbulent flow seefd FLUENT 1 June 3, 2011 04:20
SimpleFoam: Laminar vs. Turbulent Convergence JasonG OpenFOAM 0 June 2, 2011 09:29
How to determinate turbulence scale in LES (laminar simulation)? Franciswu21 ANSYS 0 October 22, 2009 13:48
modelling laminar and turbulent flow in the same Ol FLUENT 2 November 25, 2005 03:52
how to model transition laminar to turbulent? james Main CFD Forum 0 October 1, 2003 04:16
