Rotating Reference frame
Old   May 25, 2007, 12:58
Default Rotating Reference frame
Ketan
Hi All!
I have a cylinder which is rotating with 0.3 rad/sec, I am using Single rotating referance frame. I want that the cylinder should be in solid body rotation w.r.t rotating frame. So does any body know how this can be achived? Please help me. What I figured out is that I write a CFF for rotational velocity i.e Tangential-velocity/(radial-coordinate) which should be equal to 0.3 rad/sec in whole fluid domain. But when I see the contours for the CFF the only controversy is at the center which show rotational velocity as 0.6-1.2, I dont know why is it like that?
Secondly, I want to change rotating rate to 0.39 rad/sec so for this should I write a UDF or should I change the rotation rate of the wall by 0.09 rad/sec Thanks in Advance Ketan
Second Derivative Zero - Boundary Condition fu-ki-pa OpenFOAM 11 March 27, 2021 05:28
question about governing equation in CFX using rotating/non rotating reference frame rystokes CFX 0 January 12, 2010 07:14
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 01:35
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 01:34
