May 24, 2007, 12:06 |
wall heat flux
is the value of wall heat flux given directly by fluent true if not how to calculate it and how to calculate the heat transfer coefficeint (h) thanks alot |
May 24, 2007, 17:43 |
Re: wall heat flux
Calculate heat transfer coefficcient as following: htc = q" / ( Tsurf - Tavg)
Tsurf: Surface temperature Tavg: average fluid temperature q": Wall heat flux You could also compute htc directly from Fluent report: The Surface Integrals panel can also be used to generate a report of averaged heat transfer coefficient h on a surface: Report --> Surface Integrals... In the Surface Integrals panel, choose Area-Weighted Average for Report Type, select Surface Heat Transfer Coef. (in the Wall Fluxes... category) as the Field Variable, and select the surface. You have to use average fluid temperature to calculate the heat transfer coeffcient.... |
May 25, 2007, 11:15 |
Re: wall heat flux
my question is the value of heat flux given directly bt fluent is its value is correct since when I calculate the heat flux from q=h*(Tw-Tm) the value is differ from the value get from fluent
May 27, 2007, 16:15 |
Re: wall heat flux
Make sure to check the reference values used by FLUENT to calculate HF. The default temperature is 288.15K. See report->reference..
HELP - Wall Heat Flux CFX | Karkoura | CFX | 5 | March 29, 2011 12:44 |
how to export "wall heat flux" to tecplot? | victor | CFX | 3 | November 27, 2008 09:45 |
how to impose experimental dat as boundary conditi | Rogerio Fernandes Brito | FLUENT | 14 | November 25, 2008 05:47 |
CFX - wall heat flux | divarano | CFX | 2 | December 4, 2006 16:14 |
Basic question: UDF for wall heat flux | Carl | FLUENT | 1 | August 5, 2006 19:01 |
