udf as Boundary condition
Old   May 23, 2007, 07:14
Default udf as Boundary condition
anup
hii have u ever implemented a udf as a boundary condition ?? cos i hv know temp at certain positions of my wall and i want to put them as a boundary condition , so in other words its like :
x,y = 370,0 temp = 600 C x,y = 370,50 temp = 650 C . . . n so on
i m not able to write the C code .. i hv no idea what will be the inputs and how the fluent will understand the output .... can u please help me .. i thhink its a very short code ...
plzz i m stuck badly .. help
Old   May 23, 2007, 09:15
Default Re: udf as Boundary condition
Neil
If you don't know how to write the code why not just split the wall into smaller sections in the geometry so you can define the temperature for each small section individually. You may end up with alot of small sections but its a work around solution to save having to figure out how to program a UDF
Old   May 23, 2007, 12:51
Prasad Dudhgaonkar
You can create a text file (.PROF) and read it (File-Read-Profile). This profile file needs certain format. You can find it in documentation. For ready reference I am giving a specimen for two data points referred by you. x, y in meters and temp in K.
((airinlet point 2) (x 370 370 ) (y 0 50 ) (temp 873 923 ) )
Resolved: Changing boundary condition with UDF according to pressure outlet boundary alpemre Fluent UDF and Scheme Programming 12 February 24, 2014 11:18
UDF for inhomogenous Neumann boundary condition akhilesh Fluent UDF and Scheme Programming 3 December 24, 2012 12:14
Boundary Condition Types Using Scheme and UDF Nasir FLUENT 0 September 15, 2008 22:54
UDF for the boundary condition Sridhar FLUENT 3 July 13, 2001 20:18
UDF : boundary condition ID Flav FLUENT 4 June 28, 2001 10:52
