May 22, 2007, 12:57 |
Periodic Conditions - 3Dblade
Hi, I'm simulating a single 3D blade passage with periodic b.c. in the middle of the passage. I'm using the Pressure Based Solver (the Density Based Solver gives me problems). In the Periodic Conditions Panel do the Upstream Bulk Temperature and the Flow Direction refer to the inlet? The Flow Direction at the inlet is not the same as the direction of the periodic sides downstream the blade. Thanks
Symmetry and Periodic boundary conditions | CFD_Fluent_User | FLUENT | 1 | October 16, 2014 03:18 |
rotational periodic boundary conditions in ICEM | user0314 | ANSYS Meshing & Geometry | 1 | June 21, 2011 02:57 |
Activate Periodic Conditions | IvanCFD | FLUENT | 3 | May 13, 2010 08:02 |
3D non-conformal periodic boundary conditions | Simon Riverin | FLUENT | 4 | February 23, 2007 02:35 |
periodic boundary conditions | Satish Perivilli | FLUENT | 0 | January 28, 2005 12:54 |
