Density model
Old   May 16, 2007, 10:29
Default Density model
ritmat
I have a turbulent problem with a gradiant of temperature around 600 degre C. So my temperature will change as well as the density of my flue gas. So it is i think a problem of compressible flow linked to temperature and not to mach. For that i am using the incompressible-ideal gas model for density in the material set up. Is it sounded correct for you?
Atomization and Breakup model xck1986 OpenFOAM 4 May 31, 2014 05:43
A problem about density in liquid air definition alloveyou CFX 2 June 14, 2012 15:20
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 26, 2009 00:27
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
2D-vertical density current model Stone Main CFD Forum 2 February 7, 2001 14:41
