How to model a long tube embedded in the earth?
Old   May 14, 2007, 20:49
Default How to model a long tube embedded in the earth?
stefanie
Hi there,
I want to model a very long tube which is embedded into the earth. There is fluid inside. The length maybe 500 ft. I want to know parameter changes with the depth. Does anyone know how to model it? The length/diameter is too large, I dont know how to solve this problem in Fluent. Thanks.
stefanie
Old   May 16, 2007, 09:14
Default Re: How to model a long tube embedded in the earth
franz
Hi
Scale the problem down with operating figures (e.g. Re, deltap/L). At the end you should have a modle with physical and geometric alikeness. The smaller model can be simulated in fluent
Regards
Franz
Old   May 17, 2007, 15:35
stefanie
Thanks Franz,I'll try.
Good Day!
stefanie
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 08:18
HLL Riemann Shock Tube Matlab Problem Luke F Main CFD Forum 2 May 20, 2016 03:10
What is best mesh for cylinder tube? olivia FLUENT 7 January 16, 2014 06:55
Missing math.h header Travis FLUENT 4 January 15, 2009 12:48
long tube mesh asghari FLUENT 2 June 8, 2006 13:49
