May 11, 2007, 05:31 |
A gambit question
Hi all, I'm using Gambit v2.3.16 and I've some trouble in drawing a particular geometry of an industrial reactor vessel. In fact inside this vessel there's a big wall perforated pipe.
I've to extract negative volume from this geometry and gambit does not consider holes geometry. I tried with subtraction and with splitting operation without positive results. Do You have any suggestion? Thanks for advice, Best regards Adriano |
May 11, 2007, 09:15 |
Re: A gambit question
I need to extract the internal fluid volume to perform a CFD simulation. The application is in biodiesel production. No aircraft wing applications!
Gambit maillage question | stage81 | FLUENT | 0 | October 1, 2010 11:06 |
Gambit question. | Pablo Cornejo | FLUENT | 10 | March 10, 2006 10:46 |
Gambit question | LI Y | FLUENT | 2 | April 6, 2003 17:59 |
a question about Gambit | Jack | FLUENT | 5 | February 6, 2003 07:04 |
an easy question about gambit | brian | FLUENT | 3 | December 3, 2002 00:58 |
