May 10, 2007, 16:10 |
please student need to help
Hi I am student working on microchannel heat exchanger and have the following questions 1-how can I saving the temperature and velocity distribution along the interior of the channel as a data file to calculate the distribution of bulk temperature (Tm) along the channel length.And how can I calculating the Tm.
2-How can I calculating the distribution of Nusselt No. along the channel. Please help me and sending the answer to my email with thanks |
May 11, 2007, 13:23 |
Re: please student need to help
you might be able to use a Custom Field Function to plot contours of bulk temp and Nu along any surface that you want to create in the define surface panel.
Define->Custom Field Functions.... and Surface->Iso-Surface... For exporting data you can do Plot->XY Plot and pick velocity, pressure, temp etc..then choose which surface (i.e. default interior/fluid domain) you want and choose "Write to file" which will creat a data file in your working directory |
FLUENT STUDENT VERSION | Krishna C Ravi | FLUENT | 1 | November 1, 2010 02:06 |
Student Guide for CFD - Vol III, Hoffmann CODES | Amir | Main CFD Forum | 0 | August 9, 2007 08:09 |
help for a simple student | harika | FLUENT | 6 | January 10, 2006 01:18 |
Student looking for CFD software | Chris | Main CFD Forum | 6 | January 21, 2005 04:20 |
udf application in student version of fluent | arun | FLUENT | 1 | April 8, 2004 21:15 |
