May 10, 2007, 11:17 |
I don't understand
I keep getting this "Line 2: syntax error" when I try to interpret my UDF. "Line 2" is actually a blank line in my source file. That does not matter anyway because this UDF has no syntax errors in it, I've used it before without trouble and I have not modified since, not even accidentaly.
May 11, 2007, 10:07 |
Re: I don't understand
If you are not using the same machine/compiler that could be reason.
[snappyHexMesh] Trying to understand the motorBike tutorial | Andyjoe | OpenFOAM Meshing & Mesh Conversion | 10 | August 10, 2014 17:57 |
I can not understand the tutorial TJunctionFan.(OP 2.0.0) | asamit | OpenFOAM | 1 | August 7, 2011 06:29 |
CFD user but want to understand more theory | Jonny6001 | Main CFD Forum | 9 | September 14, 2009 00:22 |
Canbt understand advective amp wavetransmissive | wuwen | OpenFOAM Running, Solving & CFD | 0 | November 6, 2008 09:42 |
Help to understand these two images | Freeman | Main CFD Forum | 4 | March 15, 2006 10:21 |
