May 10, 2007, 08:52 |
Contact angle UDF
I have written a contact angle UDF.Its a two phase problem with a solid wall.UDF is getting interpreted and also running. The contact angle is showing a visible change when I see the phase contour, but the out put value of contact angle in the fluent window is not showing that value(using printf). Why this could be. Kindly help me out
help with UDF for contact angle based on contact line velocity | gandesk | Fluent UDF and Scheme Programming | 14 | October 29, 2012 14:58 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 06:50 |
UDF for Contact Angle | gandesk | Fluent UDF and Scheme Programming | 1 | November 1, 2010 10:00 |
UDF for varying contact angle (wettability gradient)) | aviitkgp1 | FLUENT | 1 | March 10, 2010 15:37 |
problems with UDF to set contact angle | poiuy219 | Main CFD Forum | 0 | April 30, 2009 11:43 |
