Boundary Conditions problem
Old   May 10, 2007, 07:06
Default Boundary Conditions problem
Manish
I am doing turbine analysis using mixing plane model.I am finding it difficult to give boundary conditions and material properties/fluid properties.Can any1 help me?
Old   May 11, 2007, 01:59
Default Re: Boundary Conditions problem
gopal
check and follow the instructions given in the fluent tutorials,its there!
Old   May 11, 2007, 03:13
Manish
Thank you for that information.I still cant solve my problem.What i want to ask you is that we are not giving any pressure/temperature/mass flow values,only the rpm.How will we get the desired analysis?? Kindly let me know
Old   May 13, 2007, 03:22
gopal
if you go through the bounadary conditions carefully u maust have come across the pressure inlet and outlet and the intrface. ur pr,in and out conditions are giving the physical conditions required for the problem.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
CG, BICGSTAB(2) : problem with matrix operation and boundary conditions moomba Main CFD Forum 2 February 17, 2010 04:37
Fluent accuracy and boundary conditions Paolo Lampitella FLUENT 0 June 12, 2008 07:25
Problem with Boundary conditions Mahiboobswamulu Main CFD Forum 10 August 26, 2003 14:24
boundary conditions problem reinaldo kuhn Phoenics 1 March 27, 2003 12:46
