I need to conduct some Aerodynamic evaluations/Assessment and I need a standard aircraft wing model........ I will be using fluent for that and I am a bit beginner and I really need help and Directions... Any useful liks or relevant sites...ect would be appreciated Thanks a lot! Mimi. |
Do you intend to model a full 3D wing or are you analysing a particular 2D airfoil? "Standard aircraft wing model" can mean a lot of things. Is this a commercial/business jet type of aircraft or is it military/transport? What about swept wing configuration? Should the "standard model" be both swept and have an angle of twist? Many things you should consider. If you plan on modeling a full 3D wing you are better of using a specific CAD package for doing so and then importing your geo into Gambit for meshing. Good luck
A A S |
AAS,
Thanks a lot for your reply! - I intend to model a standard wing (Civil airliner!) - swept wing - Am not considering twist at least at the start! - I will be using FLUENT...BUT the problem is that I still do not have a model...I am looking for one! But it must have a control surface, tipycally: An aileron! I need to conducted aero studies for different aileron deflections and angles of attackes...ect Do you know any source where I can get info or links to get a geometry... Hope to hear from you again! MiMi |
It might be a little difficult (I could be wrong) for you to find a file containing the geometry you are specifically looking for, especially on the internet. You are much better of modeling the wing on your own using a cad package like Pro/E or Catia. Once you have accomplished that you can import the file into Gambit and create a surface mesh and define your pressure far field, velocity/pressure inlet, and pressure outlet conditions. And then export your mesh file. Start Fluent and do File-->Read-->Case and choose your mesh file from the working directory. This is a pretty formidable project you are working on, good luck.
Onward and upward A A S |
Which turbulence model wor a mult-element wing? | Zweeper | FLUENT | 1 | February 21, 2010 10:48 |
How to model vortex of supersonic wing tip | Bernard | FLUENT | 0 | January 29, 2007 03:20 |
2D FAN MODEL | PIN | FLUENT | 0 | May 16, 2006 05:41 |
Fluent 2D Model - Axial Fan in a Duct | J | FLUENT | 0 | April 18, 2006 02:25 |
Aircraft wing modeling | serhat kilerci | FLUENT | 0 | January 13, 2001 14:51 |
