how to set radiation model for ch4 air combustion
Old   May 8, 2007, 13:45
Default how to set radiation model for ch4 air combustion
venkat
hi,
am presently simulating methane air mixture combustion in a model combustor problem...its non-premixed diffusion case...the domain is similar to example in tutor files.....
the case is converged and the temp are around 2370k....can any one tell how to consider the radiation effects in this modelling.....
as per the domain p1,dtrm and DO models can b considered...so please tell me how to set the radiation models......
Old   May 9, 2007, 01:14
Default Re: how to set radiation model for ch4 air combust
ssj
Dear venkat,
go through the fluent manual you will get some clear idea. as per you rdomain use DO model which is applicable to all domains but it is computationally expesive. P1 model is used when opticle thickness is >1. all the best.
Old   May 9, 2007, 11:13
venkat
hi thank u ssj,
i hav tried but not getting idea how to start...i found only theory abt those models...but not step by step procedure....
and let me know one more thing...do i hav to set the radiation on from the starting of simulation...that is right from first iteration after reading the mesh file in fluent...
.......presently i hav converged the case....and the temp is 2370 for methane air combustion...equivalence ratio is one...can u comment abt this result.....plz help me as early as possible.......thanks in advance
(the problem is non-premixed diffusion flames)
bye venkat
Nonpremixed Combustion Model for Coal Gasification C.Y.Ler FLUENT 2 April 29, 2014 09:51
Liquid rocket engine non-premixed combustion model Erik FLUENT 2 November 28, 2013 15:09
Questions for a species transport problems (snapshots attached) aleisia FLUENT 2 October 9, 2011 05:40
DO radiation model in combustion Shankar FLUENT 0 November 1, 2004 18:54
HOW TO SET CONSTRAINTS FOR COAL COMBUSTION MODEL YNW CFX 0 February 25, 2003 04:33
