turbulent viscosity ratio
Old   May 8, 2007, 00:10
Default turbulent viscosity ratio
Yijin Li
What is the range of turbulent viscosity ratio in inlet of turbomachinery?Thank you!
Old   May 10, 2007, 04:50
Default Re: turbulent viscosity ratio
Jonas Larsson
Read CFD-Wiki. There is something about this written there. What eddy viscosity ratio you have depens on which component you are interested in. It can range from say 10 for a fan rotor to say 10000 for the inlet to an HP turbine. In general I would not recommend using this as an inlet condition though. I find it more intuitive to specify a tublence level and a turbulent length scale.
Turbulent viscosity ratio Balaji FLUENT 5 May 27, 2014 04:47
hel (turbulent viscosity ratio limited) for supersonic combustion problem omar.2002bh FLUENT 2 September 5, 2012 12:04
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 01:05
On limiting to turbulent viscosity ratio! varghese FLUENT 2 November 15, 2003 09:56
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 07:13
