abnormally high flame temperatures in C2H2/Air com
Old   May 7, 2007, 14:13
Default abnormally high flame temperatures in C2H2/Air com
Victor
What might be the reason for C2H2/air flame temperature being too high (over 3300 K). I am using 1 global reaction mechanism with eddy-dissip/finite rate model. Adiabatic flame temperature for this mixture should be 1000K lower. Also, CO and H2O do not converge. The geomery and the physics of the problem are very simple.
Old   May 7, 2007, 17:25
Default Re: abnormally high flame temperatures in C2H2/Air
Allan Walsh
Heat capacity of gases not set to be a function of temperature?
Old   May 7, 2007, 17:47
Victor
Thank you !
Old   May 7, 2007, 19:00
Phil
These basic models normally over predict the flame temp.
Non-smooth transitions between coarse and dense mesh regions, or highly skewed elements are the usual reasons for poor convergence - OR NON-REALISTIC PHYSICS STRUGGLING TO SATISFY THE FUNDAMENTAL EQUATIONS. This is usually caused by getting the boundary conditions wrong or adding walls you don't notice.
Excessively high temperatures brossofor FLUENT 0 June 2, 2010 03:53
High Temperatures during compression John Siemens 2 August 29, 2007 04:42
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
Temperature is abnormally high! haiong FLUENT 5 August 29, 2004 03:23
Compressible vs. incompressible NS at high Temperatures Jean Lacroix Main CFD Forum 1 December 24, 1999 07:21
