Steam laval nozzle
Old   May 2, 2007, 16:06
Default Steam laval nozzle
Ahmet
High. I am new in CFD and also fluent. My first project is an analysis of a laval nozzle for steam. This is a small laval nozzle for a micro steam turbine. In analysis, what is the way that I follow? What is the critical points. The inlet temperature is 823 K and inlet pressure 30 bar. I have a 7 g/s mass flow rate.
Thanks for helps
Old   May 2, 2007, 16:50
Default Re: Steam laval nozzle
Phil
I'm unsure how little experience you have but the very basics of model creation are - 1)create the geometry, 2)mesh the geometry, 3)assign boundary conditions.
You should do the Gambit tutorials, this would help you a great great deal.
Then do the fluent tutorials to learn the solution process. If you already have a working model then just do the fluent tutorials but not the gambit ones.
Old   May 3, 2007, 14:44
Ahmet
I have experience basics. There is no problem. You know. This is a compressible flow. Which method should I use. Pressure based or density based. For steam properties, can I define as ideal gas
Old   May 3, 2007, 17:35
Default Re: Steam laval nozzle *NM*
Phil
Old   May 3, 2007, 17:40
Phil
The solver options change how the code reaches the solution - but not the final result if converged to the same criterion.
I would leave it standard and if it converges fine then leave it. If not then try changing from a pressure based solver. Relaxation factors are a better way to help convergence if you know how to use them efficiently.
THE QUESTION YOU ARE POSING IS MORE RELEVANT TO STABLE CONVERGENCE THAN BETTER ACCURACY(if I understand your question properly)
Old   May 4, 2007, 12:14
Ahmet
Thanks a lot first of all. I have a solution in pressure based type. but when I try it in density based and after I get the result, there is a big difference between mass flow rates. What is the reason of this?
Old   December 26, 2009, 11:26
Default Micro Nozzle Applet
Izak
isak is on a distinguished road
I am looking for a Java Applet of Laval nozzle.
isak is offline   Reply With Quote
Convergent nozzle and preesure of steam pranabjyoti CFX 7 March 10, 2011 20:23
How to configurate laval nozzle in wind tunnel?? Robert2011 Main CFD Forum 0 January 19, 2011 03:14
laval nozzle in wind tunel configuration? Robert2011 Main CFD Forum 0 January 17, 2011 18:20
Laval Nozzle in tunnel configuration? Robert2011 FLUENT 0 January 17, 2011 17:47
superheated wet steam (avoid condensation in a nozzle) Ralf Schmidt FLUENT 0 August 11, 2009 12:55
