Standard wing for aerodynamic evaluation
Old   May 2, 2007, 13:31
Default Standard wing for aerodynamic evaluation
mimi
Hi all,
I would be grateful if I could get help ...suggestions...ideas about how to get an Aircraft wing model...(a standard one with a control surface preferably an aileron )
I will be using Fluent for my Aerodynmic assessment.
Thanks very much.
M.
Old   May 2, 2007, 16:43
Default Re: Standard wing for aerodynamic evaluation
Phil
You'll need to create the model yourself using Gambit. Do all the tutorials.
Alternatively pay someone money.
Old   May 5, 2007, 04:35
H.A.S
threre no need to do all the tutorials , i think all what u shoud do is to looking for a book handling the WING issues , you will get the equations then u can solve it . Iam trying also to do the sma ething , and I am looking for that , so if u wnat we can help each other . I am also wnaa modeling the WIng on the Fluent .
Old   May 5, 2007, 12:27
Phil
I saw a reply posted on the main forum that made me realize that i think what you are looking for is the dimensions/geometry of the wing.
HAS: go and look on the main forum at the same message and you'll see a link posted by someone else to a website containing wing geometries.
Old   May 8, 2007, 04:36
mimi
Thanks guys,
I posted it twice to get more answers
HAS, Yes It would be helpful for both of us if we could work collaborate with each other...
Is the wing you are trying to consider with a control surface? if so: what kind of control surface?
Hope to hear from you sooner
M.
Old   May 8, 2007, 04:49
H.A.S
Actually I am workin on a wind turbine , but i need the wing geometry to model it on gambit and fluent . However , I may be interested in ur projects , can you please send me details of ur projects to my email . so that we can collaborate , Thanks for your reply !
Old   May 8, 2007, 04:53
mimi
Thanks for the reply!
I will send you the projects description by this afternoon
you deal with wings or turbines? I am confused!!!
Old   May 16, 2007, 09:04
Joey
I want to mesh a wind turbine using gambit. That's the problem: I can mesh all the surfaces but when i want to mesh the volume, appears one error. Check the skewness in areas of small gaps. How can I solve this problem? I redrawed all the surfaces in gambit but the problem persists.
I hope somebody can help me. Thank you very much.
Old   May 16, 2007, 09:09
mimi
interesting question! for whcih i don't have an interesting answe am afraid!
3D Wing Analysis Ed FLUENT 5 April 13, 2019 14:07
Forward swept wing simulation abid Siemens 1 June 16, 2012 14:26
[Gridgen] Blocking topology for blunt wing siw Main CFD Forum 3 July 21, 2010 14:55
Isolating wing induced drag component siw CFX 2 June 22, 2010 11:21
Looking for a standard aircraft wing model........ mimi Main CFD Forum 3 May 21, 2007 14:26
