How to use UDF in evaporation.
Old   May 1, 2007, 09:16
Default How to use UDF in evaporation.
Rikio
I am working on the refrigerant evaporization in a straight tube which is 860mm long.The diameter is 10mm. The aim is to simulate the vapor volume fraction along the tube.The B.C is: inlet, velocity-inlet, saturated liquid(R134a:a kind of refrigerant); outlet, pressure-outlet; wall, the heat flux is a constant: 10kw/m2. UDF(mass transfer) is needed. But how to define the mass transfer of phase changing from liquid to vapor? Anyone who works on the same topic could give me a help?You will be very appreciated.
Old   May 11, 2007, 11:30
Default Re: How to use UDF in evaporation.
selim
i need udf to solve condensation process of R134a.
How to simulate the process of water evaporation by UDF? qiyang860908 Fluent UDF and Scheme Programming 10 January 9, 2015 14:59
how to write udf for evaporation in heat pipe???? Anbazhagan R Fluent UDF and Scheme Programming 2 May 3, 2009 08:43
UDF for water evaporation syed FLUENT 0 March 14, 2007 23:21
UDF water evaporation emanuele FLUENT 0 March 12, 2007 17:34
Evaporation UDF MN FLUENT 0 December 8, 2003 21:37
