Instructions needed for 6.2.16 on dual core
Old   April 30, 2007, 17:40
Default Instructions needed for 6.2.16 on dual core
Demetrios
I need instructions on how to run a process on a P4 dual core utilizing both cores with fluent 6.2.16.
Many, many thanks in regard
Old   May 1, 2007, 03:52
Default Re: Instructions needed for 6.2.16 on dual core
Bogdan
fluent 3ddp -t2 and optionally -pnet
Old   May 1, 2007, 12:58
Demetrios
thanks for the reply! I am intrested in 2ddp. is it possible?
Old   May 1, 2007, 14:20
Charles
Try it? But yes, it should work. Bear in mind though that it is going to have to be a fairly large 2D problem before it will get much benefit from running in parallel. At least 200 000 cells or so.
Old   May 1, 2007, 16:16
Demetrios
how do u do u get running on dual core? Can u tell me how to ? i need you to give the settings to do so
Old   May 1, 2007, 16:25
Charles
From the command line,
fluent 2ddp -t2
should do it, assuming that you have a parallel license
Old   May 2, 2007, 01:02
joshkemp
If you have never launched from command line before, you will need to have fluent setup the environment using "Set Environment" under Fluent.Inc products in windows.
Then you can use "fluent 2ddp -t2"
Otherwise you have to type the full path to the directory in which you have fluent installed.
Old   May 2, 2007, 04:05
Demetrios
Many, many thanks to everybody! I will try it out as soon as i can
Old   May 2, 2007, 08:47
Phil
hey is that you Demetrios from the CFD centre in Leeds? It's Phil(Scottish).
solving a conduction problem in FLUENT using UDF Avin2407 Fluent UDF and Scheme Programming 1 March 13, 2015 03:02
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Dual Xeon PIV 3.8Ghz vs 2x Dual Core E5130 2.0 GHz Michiel Hardware 4 July 31, 2009 07:06
Questions about CPU's: quad core, dual core, etc. Tim FLUENT 0 February 26, 2007 15:02
How many CFX licenses for dual core processors? km CFX 12 September 8, 2006 16:18
