Gambit 3D Meshing: Error: Out of Memory
Old   April 30, 2007, 03:32
Default Gambit 3D Meshing: Error: Out of Memory
Sucho
I have modelled a Blended Wing Body (BWB) aero model and trying to analyse using fluent.
To get a reasonable Y+ value around 300, my ds is 0.05. But since the value is so small, I end up getting couple of millions of meshes just for a surface!!!
I have aleady encountered memory problem while meshing surfaces, How do i overcome this problem...??
Reynolds No. 550e+006 Reference Length. 2460 inches
And What turbulent model ahould i use for the this case?
Old   May 2, 2007, 08:13
Default Re: Gambit 3D Meshing: Error: Out of Memory
Phil
memory problem generally means you are trying to do more than your computer can handle. Use less cells or get more RAM!
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 06:22
Gambit meshing error jx FLUENT 11 May 26, 2009 11:35
Gambit: too long meshing time! delsolman FLUENT 1 January 29, 2008 20:06
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 10:22
