Compresssible flow
Old   April 29, 2007, 16:54
Default Compresssible flow
John
Hi' I am having problems with understanding the boundary conditions for compressible flow.
I have a gas pipe with a gas pressure on 3barg, which enters into many small straigh pipes that is connected to the ambient.
I try to model only the small pipe (one) and the flow into ambient.
I set the operation pressure to 1 bar. I set the the inlet boundary to the small pipe as a pressure inlet, with Gauge Total pressure to 3 barg. The supersonic/initial gauge pressure I have set to zero. (I really do not understand what is meant with the supersonic/initial gauge pressure)
I know the static temperature in the gas pipe, but I assume it is the total temperature I have to set for the inlet.
Any help is appreciated
Old   April 30, 2007, 02:45
Default Re: Compresssible flow
Sina Akbari
Supersonic/initial gauge pressure has no effect on your boundary condition if your problem is subsonic but when mach number exceeds 1 then this pressure will came into account, also I suggest you to set mass flow at the inlet B.C.
Let me know if you are successful in solving your problem. Sina
Old   May 3, 2007, 09:41
Subrata
In case of compressible flow if problem is subsonic it has been told there is no effect of supersonic or initial gauge pressure. in my case initial pressure is 4 bar. Can i give that supersonic or initial gauge pressure is 2 bar or 0 bar. please suggest
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
What is the difference between liquid reactive flow and gas reactive flow? James Main CFD Forum 6 May 15, 2009 13:14
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 08:40
Plug Flow Franck Main CFD Forum 3 September 4, 2003 06:57
