Can Fluent find natural frequency?
Old   April 28, 2007, 09:08
Default Can Fluent find natural frequency?
Ken
I have created a cicular cross section in GAMBIT to model a cylinderical structure and had exported the mesh file to FLUENT. I am trying to determine the natural frequency of the cylinder in FLUENT? Do you know any command in FLUENT that can determine the natural frequency, either both in air or water?
Thanks KWong
Old   May 2, 2007, 14:56
Default Re: Can Fluent find natural frequency?
Will
You don't need Fluent to do this. If your Reynolds number is between 2000<Re<200000 then you can just assume a Strouhal number of 0.2 and go from there.
Old   May 3, 2007, 04:56
Ken
If i do not need FLUENT to do this, then what do i use??
Thanks
Old   May 3, 2007, 15:12
Will
For a cylinder in crossflow the Strouhal number, S = fD/U, (f = frequency, D = cylinder diamter, U = mean flow velocity) is pretty much constant for Reynolds numbers from 2000-200000. Just solve for the frequency.
Old   September 23, 2014, 15:53
Default natural frequency
saeed
saeedjack is on a distinguished road
i modeled an external flow with fluent 6.1, how i can find natural frequency of it? if its possible or not?
and what is exactly output of acoustic model in fluent?
saeedjack is offline   Reply With Quote
Old   September 23, 2014, 21:40
ringtail is on a distinguished road
First, start the unsteady simulation of the flow until the flow become stable. I mean the vortex shedding become regular. Then monitor the lift of the cylinder for some time. After that, Do FFT to the lift data, and you will get a peak frequency. Generally, it is the natural frequence.
ringtail is offline   Reply With Quote
Please help: - To find torque in Fluent.......... Jayanth FLUENT 1 July 5, 2018 18:23
If I know one cell in the fluent ,how to find some other neigbor cell of it . wwt650420 FLUENT 0 March 23, 2011 12:12
Fluent 6.3.26 vs 12.1 and partition method Anorky FLUENT 0 April 27, 2010 11:55
Natural convection in Fluent Tanveer Main CFD Forum 4 May 20, 2008 13:31
where to find old version Fluent tutorial guid Roger FLUENT 0 March 11, 2002 18:04
