April 27, 2007, 19:03 |
Need help in turbulence modeling
I am trying to model a cooling ciruit in a rotating turbine blade. I started off with a circular channel for start, and was trying to examine the heat transfer characteristics with a stationary tubulent flow at first. I tried using the K-Epsilon model with wall function but i could not get a Yplus value above 30. So i tried to coarsen my grid and increase the reynolds number until i got it. However, i noticed a problem once i plot the velocity profile at different points along the channel, the velocity is not zero at the wall. I tried using the LES and the Sparlat Allmaras model and there is still a velocity value at the wall. I've exhausted myself trying to increase the pipe diameter, refine or coarsen the grid but there is no avail. Can anyone help me on this? |
May 2, 2007, 11:04 |
Re: Need help in turbulence modeling
I am trying to use the k-epsilon model in fluent and the convergence is almost right away after about 50 iterations. help please
May 2, 2007, 11:20 |
what is the problem? if you don't have many cells then it could converge after 50 iterations. Are you using 2d? if so that sounds ok.
Andrew - sorry your question is too long, i fell asleep after the first 2 lines. |
May 5, 2007, 20:39 |
Its alright, i got it to work already. Will try to better sumarise my question next time.
Thanks anyway. |
Turbulence postprocessing | Mohsin | FLUENT | 2 | October 3, 2016 15:18 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 10:52 |
May Focus Area: Turbulence Modeling | Jonas Larsson | CFD-Wiki | 0 | May 2, 2006 12:48 |
turbulence modeling questions | llowen | Main CFD Forum | 3 | September 11, 1998 05:24 |
