when i compile the UDF, that donot get connected. and during that i receive error: unable to open udf file. my question is khow to rectify this?
this is also with the tutorial that is given in fluent help. i am using fluent 6.2.16 version. does this a version problem? thanks in advance regards, mvee |
If u're using the XP version, install visual c++ 2005; and I recommend u to compile from a ms-dos prompt, not directly in fluent.
thomas |
i have turbo c and borland c compiler. does these compilers are not sufficient?
mvee |
Actually they're not... You're not just compiling a stand alone c program! In your UDF u've utilized Fluent's macros contained in udf.h or in others *.h Fluent's files; so your compiler must contain utilities to link them. I think there are also some others functionalities of the visual c++ compiloer that are strictly needed to compile UDFs...
thomas |
UDF compilation problem on Linux System | Nitin Pathak | Fluent UDF and Scheme Programming | 6 | September 29, 2018 20:26 |
UDF compilation error | Szabolcs Varga | Fluent UDF and Scheme Programming | 4 | September 14, 2015 05:27 |
UDF Compilation error | pstreufert | Fluent UDF and Scheme Programming | 0 | September 12, 2011 14:25 |
UDF compilation problem -- "undeclared variable" | Henrik Ström | FLUENT | 1 | September 21, 2005 05:25 |
Compiled UDF / Compilation problem | mikhail | FLUENT | 1 | October 13, 2000 06:12 |
