Error in memory
Old   April 23, 2007, 17:35
Default Error in memory
Dave
Hi, I'm working with a 3d simulation with 1632823 nodes. i have this error when i try to iterate Error: 1000000: Failed to allocate 70.02MB memory (..\..\src\amgif.c:1068)
I've tried in two different computers, one with a 1 Gb of RAM, OS= winXp, Intel pentium 4 CPU 3.8GHz and other with 2 Gb of RAM, Os windows vista, intel core 2 duo CPU 2.2 GHz . However the error continues!!!!
what can i do for run the simulation?
Old   April 23, 2007, 17:43
Default Re: Error in memory
Tim
Are you using a polyhedral mesh? The cases I tried use an enormous amount of memory, so I gave up.
Old   April 23, 2007, 21:51
Dave
the mesh is a structured mesh, conformed by hexahedral elements. the volume have a boundary layer. i tried with the pressure solver and density solver explicit and implicit.
Old   April 24, 2007, 11:02
nick
Hi, I had the same problem. Initially my mesh was about 3E06 nodes, than I reduced to 1.5E06 nodes and still I had the same memory allocation error, using a dual core 3GHz each with 4GB RAM. With the same mesh and using the two CPUs in parallel I was able to run the simulation. I Hope this help.
How to optimize the memory usage when using FEM vasilis Main CFD Forum 11 August 25, 2009 00:57
Memory error? Young CFX 3 September 30, 2008 12:33
Out of Memory Naghman Khan FLUENT 3 August 30, 2007 07:08
CFX CPU time & real time Nick Strantzias CFX 8 July 23, 2006 18:50
Run-Time memory conifguration Error Graeme CFX 1 February 21, 2006 00:04
