April 19, 2007, 16:11 |
The incompatible of UDF
Hello, everyone. I have a problem of compiling my UDF. Previously, I use version FLUENT 6.2.16 and compiled some UDFs, which really worked for me. Today, a new version FLUENT 6.3 is served for me. When I tried to load the UDFs, it said that it is incompatible. Does anyone meet such problems before? How to deal with this problem? Thanks in advance!
April 20, 2007, 06:04 |
Re: The incompatible of UDF
why not use the old version for your simulation if the new version cannot provide additional benefit or significant improvement for your case?
April 20, 2007, 09:20 |
The thing is that I am using the FLUENT from OSU supercomputer center and it seems that I could not choose which version I will use. The good news is that I have solved this problem. This morning I deleted all the old files from UDF and compiled it again, and the new generated libuf works for me. I think probably it is the way to solve this problem. Thank you any way.
April 23, 2007, 05:11 |
you can try the option -r6.2.16 for the old version of FLUENT.
For example: fluent -r6.2.16 2ddp |
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 08:37 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 23:14 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 22:38 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 05:03 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 05:01 |
