Variable Pressure Input
Old   April 19, 2007, 11:18
Default Variable Pressure Input
Chakra
HI i am using the CFD for well modelling. But there is a problem in Hydrostatic Pressure input. How can i input the variable pressure distribution around the well domain varying from surface with depth?
someone can help on this thanks
Old   April 20, 2007, 06:06
Default Re: Variable Pressure Input
jonglee
check the UDF manual, there is an example of specifying fully-devoloped inlet velocity, may be helpful for you.
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 11:08
Pressure Rise Error emueller CFX 0 May 5, 2009 12:08
Input flowrate and outlet pressure in a cylinder philippe FLUENT 0 June 23, 2008 05:48
Variable outside pressure Neser25 CFX 9 June 5, 2006 13:37
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
