pressure drop calculation multi-inlet-outlet syst.
Old   April 18, 2007, 20:04
Default pressure drop calculation multi-inlet-outlet syst.
timmyy
I have a question about calculating the pressure drop of the system of pipes. If there is a single pipe, the pressure drop can be calculated as follows: press.drop = avINLETpressure - avOUTFLOWpressure.
But my system consists of 3 inlet pipes perpendiculary connected to the main pipe and 2 outflow pipes connected to that main pipe as well. Should I just take an average pressure of 3 inlets and then substract it from the average pressure of 2 outflows? Can anyone tell me is that approach correct?
Many thanks for your advices and any suggestions about calculating the pressure drop of that system.
Old   April 24, 2007, 07:03
Default Re: pressure drop calculation multi-inlet-outlet s
kalaichelvan
RESPECTED Sir/Madam,
im a mechanical engr , write now im starting my carrer in pneumatics conveying sytems ,need ur technical support .
thanking you
Regards, KALAICHELVAN.M
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 03:10
Pressure driven laminar flow simpleFoam pressure higher at the outlet than inlet gabriel OpenFOAM Running, Solving & CFD 16 September 30, 2009 19:20
Pressure drop trend phyiscal not correct in t pipe Vinod FLUENT 0 August 4, 2008 03:43
pressure drop between inlet & outlet Ahmed CFX 6 June 14, 2008 14:49
Pressure Drop - Please Help - Simple Pipe Flow Joe A. FLUENT 2 April 23, 2007 08:50
