April 11, 2007, 05:37 |
received fatal signal
HELLO EVERY ONE
my udf is intrepreted well when i start iterating it gives like this. Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: () so please can any one suggest me wat is the reason? |
April 12, 2007, 13:49 |
Re: received fatal signal
maybe same variable is not correctly defined or non well hucked...
Check them Regards Adriano |
FLUENT received fatal signal (ACCESS_VIOLATION) | CHAKER | FLUENT | 4 | December 11, 2015 04:20 |
FLUENT received fatal signal (ACCESS_VIOLATION) | jwt | FLUENT | 2 | July 1, 2010 09:35 |
FLUENT received fatal signal (ACCESS_VIOLATION)??? | Jinfeng | Fluent UDF and Scheme Programming | 1 | October 19, 2009 12:03 |
FLUENT received fatal signal (ACCESS_VIOLATION) | samy | FLUENT | 0 | November 10, 2007 14:09 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 16:16 |
