April 10, 2007, 10:16 |
How to specify varying gravity
How do I specify gravity (or local acceleration) as a varying variable with radius: a = omega^2 * Radius ? I have a case with a rotating system where the flow is driven by the rotation. I have successfully applied a constant acceleration as gravity, but for rotating flow that varies with radius.
April 12, 2007, 07:39 |
Re: How to specify varying gravity
I think in your case, constant gravity is sufficient. The centrifugal forces will be generated automatically when you use MFR or rotating mesh.
All the best. |
Simulation of sloshing by time varying gravity | Manoj Kumar | FLUENT | 3 | June 13, 2011 04:34 |
how to model varying gravity in Star CCM+ | mohan makana | STAR-CCM+ | 1 | November 25, 2009 02:06 |
how to consider gravity in CFX | shrimp | CFX | 4 | September 8, 2008 21:41 |
variation of gravity with time | rajani | FLUENT | 0 | February 16, 2005 03:45 |
On gravity modelling... | Drona | CFX | 7 | November 22, 2001 11:28 |
