Error: invalid argument [1]: improper list
Old   April 10, 2007, 04:03
Default Error: invalid argument [1]: improper list
Ralf Schmidt
Hi!
I have a very large mesh (ab. 2.000.000 cells) with k-w, no energy eq. that runs not very stable. However, it runs
But, when I interupt iterating, save the file, take a look at the results and start again, Fluent gives following message:
Error: GENERAL-CAR-CDR: invalid argument [1]: improper list
Error Object: #f
When I read case and data again, the iteration works fine... until I turn on energy eq. or another turbulence model. Once, i run it laminar, and when i turn on any turb. model, the error message came...
So any help is highly appreciated!!!
Ralf
Old   April 10, 2007, 18:08
Default Re: Error: invalid argument [1]: improper list
Phil
If I am understanding you properly then I occasionally get this problem. I just re-read case and data then forget about it. Has never caused me any problems.
Old   April 11, 2007, 14:29
Ralf Schmidt
Hi!
thanks for answer, but it didn't worked. Could it be because of the error message fluend gives, when it reades the grid:
Warning: Number of nodes read (1057672) does not match number referenced (1056748).
Resetting counter to match the number referenced.
Ther is somewere a volume, that has only one face meshed, and that is not exported - could that be the reason??
Ralf
Old   April 11, 2007, 15:35
bashu
Have you defined any monitors?
Old   April 12, 2007, 03:29
Ralf Schmidt
yes and now. I defined some, but even when I turn them off the error appears
Old   April 12, 2007, 09:28
bashu
When I define the monitors and then change some paramters the monitor definitions sometimes get messed up. It looks like you don't have similar situation.
Old   April 12, 2007, 13:33
Ralf Schmidt
Hi!
I thing the problem is solved, at least it didn't appear any more.
I don't know, what is different - i worked on the grid again and made it really good quality mesh (ab 95% of the cells have a skewness below 0.2
I read the mesh again, iterated, saved, turned on energy eq. iterated again and the error appears again
Than I read the file again, iterated untill convergence, turned on energy eq. and continued to iterate was no problem!! Until now, the file runs very fine!
So, what ever the problem of fluent is - it seems to me to be a little random. However, hoping that "&*'?"§$ error will not appear anymore!
Ralf
Old   May 29, 2017, 06:26
rajugsr
gr135 is on a distinguished road
Hey,
I happen to get the same error in fluent when I try to load MHD add-on module after selecting non-premixed combustion.
Can someone point out to why is it happening?
gr135 is offline   Reply With Quote
Error: GENERAL-CAR-CDR: invalid argument [1]: improper list ddavies FLUENT 12 August 24, 2023 03:05
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
Parallel FOAM FATAL IO ERROR msrinath80 OpenFOAM Running, Solving & CFD 1 July 28, 2006 13:48
