Backwards compatibility of Fluent 6.3 with 6.2
Old   April 4, 2007, 10:57
Default Backwards compatibility of Fluent 6.3 with 6.2
Brian
I have recently upgraded my installation to 6.3, but am also using a cluster which is still running FLUENT 6.2. When I try to load a case file that has been saved on my local (v 6.3) machine onto the cluster (6.2), I get the error message:
Error: Set_Thread_Variables: wta(real) Error Object: ((constant . 1) (profile "" ""))
If I am running interactively on a single processor, it will still run okay. However, when trying to run on the cluster in batch mode FLUENT fails. I have also noticed that after loading into interactive mode (which spawns the error above), it will not read profiles. There are no UDFs in the case file, just one profile.
I have found two other posts here that refer to the same or similar problems (http://www.cfd-online.com/Forum/flue...cgi?read=39951 and http://www.cfd-online.com/Forum/flue...cgi?read=47266) but found no solutions. Running solely on version 6.3 is not really an option because upgrading the cluster will require a huge amount of work to get the queueing system up and running again. Does anyone have any other ideas?
Old   April 4, 2007, 22:52
Default Re: Backwards compatibility of Fluent 6.3 with 6.2
suvash
Yes. I am also facing the same problem... Please help if anybody knows the solution...
"printf" udf on fluent 6.3 salzferkel Fluent UDF and Scheme Programming 3 May 24, 2012 15:28
Rocks 5.4 Rsh Connection Refused for Fluent 6.3 bucnikf90 Hardware 2 March 29, 2012 17:24
What the differences flow equation of Fluent 6.3 and Fluent 12.1 opehterinar81 FLUENT 0 August 19, 2011 12:55
How to import mesh from ICEMCFD to Fluent 6.2 jeevan kumar CFX 5 October 20, 2008 06:41
Moving Dynamic Mesh in Fluent 6.2 R.M.Bharath Somayaji FLUENT 0 January 9, 2006 21:36
