RE:Change roughness of a cylinder in FLUENT!please
Old   April 2, 2007, 23:41
Default RE:Change roughness of a cylinder in FLUENT!please
Ken
I saw post in the forum below stated that to change the roughness of a cylinder, we have to go to 'define-boundary condition-momentum-roughness'
I cant find 'momentum' under boundary condition, only inlet, wall, etc.
Can anyone plese tell me the exact and correct method for changing the roughness of a cylinder in a flow please?
Really appreciate it !
Thanks Ken
Old   April 3, 2007, 04:12
Default Re: RE:Change roughness of a cylinder in FLUENT!pl
Gernot
If you choose wall as boundary condition a window opens where you can set the conditions for thermal/DPM/momentum..... If you click momentum you can choose wall roughness. hope that helps Gernot
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 14:00
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 07:24
[blockMesh] Specifying boundary faces failes in blockMesh blaise OpenFOAM Meshing & Mesh Conversion 0 May 10, 2010 04:56
rotating cylinder using sliding mesh Tim Daly FLUENT 1 November 10, 2008 00:02
