subgrid turbulent viscosity for UDF in LES
Old   April 2, 2007, 09:27
Default subgrid turbulent viscosity for UDF in LES
David TAIEB
I try to compute a flamme in LES with a PCM method. So I have made a UDF. And for the source terms of Z_var, Yc and Yc_var, I have to use the subgrid turbulent viscosity. I lookes in the UDF Manual of Fluent which said that C_MU_T(c,t) will be good. But I have some problems, and I think that C_MU_T was good for RANS computations but not for LES. So is someone knows how to get the subgrid turbulent viscosity for LES computations in Fluent?
Thanks
Regards
David
Subgrid Turbulent Kinetic Energy in LES saqure ANSYS 3 September 7, 2012 17:44
Link between eddy viscosity and subgrid-scale turbulent viscosity in LES Marvin Main CFD Forum 6 December 4, 2009 12:08
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 01:05
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 07:13
