DMP mass flow rate
Old   March 30, 2007, 14:47
Default DMP mass flow rate
Don Parsons
I am working on a sampler case using the discrete phase model in FLUENT. I was wondering what the mass flow rate you set in the injections window does. It seems to me that if you specify a particle diameter, particle density, and an initial velocity that the mass flow rate would be set by these parameters. The problem seems to be over specified. I know this is not the case and I am hoping someone could correct my confussion. Thank you all in advance.
-Don
Old   March 30, 2007, 18:34
Default Re: DMP mass flow rate
Allan Walsh
In reality, there could be say a million particles per second entering a domain, but you only have computational resouces to model a thousand. So each of the thousand is representative of many more particles. There is a factor that lets Fluent know how much of the overall particulate phase is represented by each particle.
Old   April 2, 2007, 12:14
Don Parsons
Thanks for the quick response. That helps a lot. The FLUENT manual does not make much mention of this fact.
Old   April 17, 2007, 03:30
vadivelan
what is the factor u r talking about? In what way fluent will do correction for those things? As i have understood it calculates for the value of parameters we have given.
Particle Injection Mass Flow Rate and Position leonozx FLUENT 3 March 9, 2018 10:58
CFX turbo - Mass flow rate Vashishth Patel CFX 7 April 3, 2014 21:33
Mass Flow Rate is not converging destgir448 CFX 5 December 11, 2010 06:55
negative global mass flow rate Gimli FLUENT 0 April 21, 2006 08:17
mass flow rate error Masood FLUENT 0 May 22, 2005 01:32
