Parallel UDF Error
Old   March 29, 2007, 12:15
Default Parallel UDF Error
Andrew
I'm new to Fluent and I can't figure out how to fix this error. I have a UDF to set a velocity profile that works fine in serial mode, but when I try to use it in parallel mode, I get the following error:
cpp -I\\d4600\fluent.inc\fluent6.2.16/src -I\\d4600\fluent.inc\fluent6.2.16/cortex/src -I\\d4600\fluent.inc\fluent6.2.16/client/src -I\\d4600\fluent.inc\fluent6.2.16/multiport/src -I. -DUDFCONFIG_H="udfconfig-node0.h" \\d4600\working\swirl100.c
error: udf compiler: cannot execute cpp -I\\d4600\fluent.inc\fluent6.2.16/src -I\\d4600\fluent.inc\fluent6.2.16/cortex/src -I\\d4600\fluent.inc\fluent6.2.16/client/src -I\\d4600\fluent.inc\fluent6.2.16/multiport/src -I. -DUDFCONFIG_H="udfconfig-node0.h " \\d4600\working\swirl100.c
I start Fluent from my working directory and when I try to interpret the udf, it gives me this error. I have been able to run other cases in parallel, but none using UDF's. I would greatly appreciate any help with this problem. Thanks.
-Andrew
Old   March 30, 2007, 03:39
Default Re: Parallel UDF Error
Bogdan
Try to compile your UDF instead of interpret it.
Old   March 30, 2007, 12:11
Andrew
Thanks, that fixed it. I appreciate your help!
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 02:40
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 06:48
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 13:34
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 06:18
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
