convergence problem
Old   March 25, 2007, 08:53
Default convergence problem
ammi reddy
hi i am modeling a pulse tube refrigerator. In this project their is linear compressor which i modeled using dyanamic meshing and a UDF. but their is the problem of convergence. This problem is unstedy, axisymetric, segregated solver.it is closed domain so i cant take incompressible flow, under relaxation i has taken are vel=0.3
pr= 0.2
energy =0.8 please help if u have any sugestion.i am geting nearer to desire result but countinuty is not going below 1e-2 . plz help.
thanking u
ammi reddy
Old   March 28, 2007, 18:01
Default Re: convergence problem
Seyed Farid Hosseinizadeh
Hey: Most of the time the residual for continuity around your numbe looks good. But if your results are suspended my advise as follow as below: 1- Chandge your number of mesh. Some time more, some times less. It depends. 2- Change your time step by calculating the dominat time scale in your physical system. You must know this number and choose a smaller value than this number(less than of half of it) 3-Change your underrelaxation factor to smaller one . Some times in the first itteration maybe you can choose 0.001. But you can change them when you get the better results in the process of solving. 4- Change your initial values to values that are reasonable nad make sense. 5- Check your non-dimensional Numbers in your system. Sometimes with choosing a lower number you can get the results and you can use this result as your initial guess for your exactly non-dimensional numbers.
Thanks/farid
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 07:00
convergence problem commonyue Main CFD Forum 1 December 1, 2009 04:54
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 23:18
Non Convergence of 3D Heat transfer cfd problem Balraj Main CFD Forum 3 December 9, 2004 01:24
