Fluent parallel
Old   March 24, 2007, 00:22
Default Fluent parallel
poovanna
Hi, I have a serious problem in parallel processing. my mesh size is 10.5 million, would be using Fluent 6.3 parallel for reacting flow and CHT analysis. am using HP workstation xw8200, dual core processor, 8GB RAM and would be connecting another HP workstation xw6200, dual core processor, 4GB RAM. am not able to import the case file when the above said machines are connected in parallel. it gives a error message stating
0 (..\..\src\mpsystem.c@1123): mpt_read: failed: errno = 10054
0: mpt_read: error: read failed trying to read 4 bytes: No error
2 (..\..\src\mpsystem.c@1123): mpt_read: failed: errno = 10054
2: mpt_read: error: read failed trying to read 4 bytes: No error
1 (..\..\src\mpsystem.c@1123): mpt_read: failed: errno = 10054
1: mpt_read: error: read failed trying to read 4 bytes: No error
999999 (..\..\src\mpsystem.c@1123): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 4 bytes: Invalid argument
The Parallel FLUENT process could not be started.
Your suggestions are welcome. thanks in advance,
Parallel running of Fluent Bhanu Gupta FLUENT 3 April 7, 2011 10:32
Parallel Fluent +UDF Jack Martinez FLUENT 0 June 28, 2007 12:19
Fluent Parallel SUPPORT MOHAMMED TOLBA FLUENT 1 February 20, 2006 02:27
Parallel Fluent with Mandrake Daniel Dotta FLUENT 1 May 19, 2005 16:30
error parallel fluent session Diet FLUENT 2 January 27, 2005 13:31
