Segregated or Coupled? High Speed Flow Mixing. |
March 23, 2007, 10:58 |
Dear all,
Situation: I am simulating flow mixing in a tee joint for compressible gas, where the flow speeds varies from 0.1 to 0.8 Mach. I tried both segregated and coupled solvers & got difference in results in the recirculation zones created after flow mixing. The pressure distribution downstream also give different contour plots. Question: 1- Based on flow details, with which solver should i continue my simulations? 2- Other than fluent help files, does anyone has any other reference for the crieteria of selection of the solver? thanks to all for the time and expected suggestions. Regards Mazhar. |
March 28, 2007, 17:04 |
Re: Segregated or Coupled? High Speed Flow Mixing.
Hey: Can I see what is your numerical method's name? Maybe I can do some help. Thanks/Farid
March 29, 2007, 10:53 |
Thanks alot for your reponse.
I am using fluent 6.2.16. The numerical scheme set up is summarized as: Solver: segregated Turbulence Model: K-epsilon realizable Pressure Velocity Coupling: SIMPLEC Skewness Correction: 0 All under relaxation factor 0.8 (pressure,density,body forces,momentum,turbulent KE, turbulent diss rate,energy) Descretization Schemes: Pressure ==> Standard Density ==> First Order Upwind Momentum ==> First Order Upwind Turbulent KE ==> First Order Upwind Turbulant Diss Rate ==> First Order Upwind Energy ==> First Order Upwind The grid is structured, aligned in flow direction. For further information, when i ran these simulation they give satisfactory results till 0.4 Mach. BUT BEYOND THIS (0.5 - 0.8) THE SOLUTION DIVERGES IMMEDIATELY AS I SHIFT FROM INCOMPRESSIBLE TO COMPRESSIBLE. Sorry for inconvinience in reading a lengthy message. Thanks and Regards, Mazhar. |
Segregated or Coupled flow? | hamzamotiwala | STAR-CCM+ | 7 | October 25, 2011 19:35 |
Coupled Flow model | RalphS | OpenFOAM | 1 | November 15, 2010 03:51 |
Some confusion about coupled solver for incompressible flow | bearcat | Main CFD Forum | 0 | February 14, 2010 20:40 |
High speed flows | Raj | FLUENT | 4 | January 10, 2006 04:14 |
Segregated or coupled solver? | Nori | FLUENT | 0 | September 29, 2005 14:24 |
