unsteady DPM particle tracks animation
Old   March 22, 2007, 09:51
Default unsteady DPM particle tracks animation
Don Parsons
I am a graduate student that is relatively new to FLUENT. I am working on a vortex sampler and would like to use the unsteady DPM. I would like to be able to display a video of some type of the particle paths. It appears that FLUENT only records the lst position of the particles if the flow is unsteady. I would really appreciate it if someone could offer some advice on how to create this sort of video. Is there a way to write the particle positons at every time step. Thank you all in advance
Don
Old   March 25, 2007, 15:20
Default Re: unsteady DPM particle tracks animation
Sujith
if the flow is unsteady fluent displays only the final positions of the particles. You can save images of particle tracks every time steps using solve-execute commands. Type the tui commands to display particle tracks as first command. ("Dis par ---") Type "Dis hc particletrack%t.jpeg" as second command. make the commands to be executed at every time step. before starting the iterations you have to set the image type through file-hardcopy.
best regards -Sujith
Old   March 26, 2007, 10:32
Don Parsons
Thank you very much I appreciate the help. I will try to apply that this week. I was wondering if the solve---animate window did the same thing or is this what you are refering to. Thanks again.
Don
Old   March 26, 2007, 14:51
Sujith
yes u can animate it thru solve->animate.. but the files will be quite big.
Old   May 18, 2012, 18:14
Jessica Simberg
Jessica.S is on a distinguished road
You could also Auto save each time step and use CFD post to create any animation that you like...
Jessica.S is offline   Reply With Quote
Old   March 2, 2016, 03:52
Rupesh Verma
roopesh99 is on a distinguished road
I tried but unable to track particle in ANSYS. I used the following technique
calculation activity-solution animation-animation seq 1-define-particle track-phase (particle)-track
But unable to track particles...
pls tell any effective way also i tried google but it is not helpful..
Thanks
roopesh99 is offline   Reply With Quote
Particle tracks - animation mneo FLUENT 6 July 5, 2012 14:30
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
Steady state DPM - Convergence and particle tracks Sandilya Garimella FLUENT 2 March 28, 2008 16:53
DPM particle tracks - speed up? Greg Perkins FLUENT 0 September 5, 2003 03:56
steady or unsteady? (in dpm) winnie FLUENT 1 April 28, 2003 12:30
