Modelling Coal Combustion like a fluid
Old   March 21, 2007, 05:46
Default Modelling Coal Combustion like a fluid
Dr. Flow Squad
Does it make sense to model combustion of coal using a "fluid" approach just like combustion of methane into air, or is it better to use a DPM approach to model the coal particles?
I've noticed the Tutorial No. 13 "Modelling Species Transport and Gaseous Combustion", and I wondered if I could use coal instead of Methane leaving anything else unchanged?
Old   March 21, 2007, 14:47
Default Re: Modelling Coal Combustion like a fluid
Allan Walsh
It depends on what you want to evaluate. Quite often we are modeling a biomass boiler that has some supplemental pulverized coal, oil, or gas firing. We are interested in how the biomass burns, but can't ignore the coal burners from a heat input, oxygen demand, and fluid flow point of view. In these cases, we have modeled the coal as an equivalent amount of methane.
Certainly if you wanted to look at something like NOx emissions from the coal you couldn't use this approach. Perhaps you could try modeling the coal both ways, and let us know how it turns out.
Combustion Modelling Srivatsan V. Rajagopalan FLUENT 18 December 1, 2020 10:38
Problem on EDC model for coal combustion lei FLUENT 4 September 3, 2015 10:39
Turbulent Dispersion for Coal Combustion gravis CFX 2 March 24, 2010 00:56
coal combustion in cyclone seperators ganesh kumar FLUENT 0 July 3, 2006 02:50
Coal combustion with Fluent 4.5 or 5.0! Sriram Popuri Main CFD Forum 2 July 24, 1999 12:34
