March 20, 2007, 22:38 |
Negative volumes
As part of my Aircraft Design Project I am doing CFD on an NLF airfoil with varying AoAs and Aileron/Flap settings. The airfoil with 0 aileron and flap deflection works fine - meshed and ran in fluent without errors. My problem is with the airfoils with aileron and flap deflections. I meshed the airfoil with a -2 deg deflection of the aileron the similar to how I did the airfoil with no deflection, however when checking the grid in fluent with the meshed airfoil with aileron deflection I get a Failed grid check error due to negative volumes. Are there any suggestions as to how I may remedy this? What I have tried thus far is changing the mesh size/type with no luck. Thanks in advance! |
March 29, 2007, 02:49 |
Re: Negative volumes
Check the skewness of the face meshes. Try to bring them down below .7 Should work fine. Thanks Regards Rohan |
March 29, 2007, 08:46 |
Thanks for the response. I've actually figured it out a while a go and have moved on from the airfoil to the fuselage.
Thanks again though |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
negative grid volumes when adapting | Dave | FLUENT | 1 | August 20, 2005 13:47 |
Problem in identifying Negative volumes in Fluent | Senthil | FLUENT | 1 | April 19, 2003 10:16 |
