March 19, 2007, 06:07 |
Modelling a fin as a wall or a face??
Hi i am doing a heat transfer simulation for fins in a rectangular enclosure with internal fins. Inside the enclosure there is a material and I want to study the melting of this material.
My simulation requires me to apply a heat flux from the base of the enclosure. Initially i modelled the base wall as just an edge in gambit and set it as a wall. I inputed heat flux= 10750W/m2 and thickness=0.5mm. After that I tried modelling the base wall as a solid face(thickness=5mm). I set the inner edge and outer edge as walls. The outer wall i set heat flux=10750W/m2 and thickness=0 while the inner wall i set it at coupled(because it interfaces with another liquid material inside the enclosure), heat flux=0 & thickness=0. However, I am getting different results for both this models!!!! Any ideas how come? |
March 28, 2007, 18:19 |
Re: Modelling a fin as a wall or a face??
Hey: I mean both of them can be correct. You mean when you add the thickness of wall get another results? I guess they must be two different results. As far as I know a fine is a surface. Thanks/Farod P.S.: I guess I didn't get exactly what are you asking about. Please let me know more.
March 29, 2007, 01:12 |
Hi Farod thanks for your reply.
Basically i modelled the fin just as an edge and selects its boundary type as wall(conductive and thickness=0.5mm) But since the wall is only an edge, i am not able to see the temperature countours Then i modelled the fin as a face(made out of 4 edges) and selected all four edges as walls. And i choose the continium as solid(aluminium) However i am getting 2 different results... Any ideas why?? Thanks in advance |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 01:04 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
Mixed Wall Face | abir | FLUENT | 0 | December 13, 2009 13:35 |
Wall Shear force - any suggestions on turbulence modelling | Bo Jensen | Siemens | 1 | February 22, 2000 13:12 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 02:16 |
