HTC for low Y+ walls
Old   March 15, 2007, 16:55
Default HTC for low Y+ walls
Tang
Hello, I am fairly new using Fluent. I have a simple flat plate model with Y+'s ranging from 0.03 to 0.3. When I plot the wall function HTC's I get values that are unreal. I have now read that Fluent wall function cannot be used for low Y+. So, my question is how come Fluent did not include a HTC calulator internally for low Y+. Also, how can I calculate then the HTC for my low Y+ model. Thank you.
Target Mass Flow Rate Nitin FLUENT 9 June 17, 2017 11:30
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 14:00
Problems with the density at walls for a compressible flow david39 OpenFOAM Running, Solving & CFD 0 February 8, 2010 13:33
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
Turbulent flow at walls in complex flows Bo Jensen Main CFD Forum 2 March 23, 2000 23:42
